Switch 4507 data flow.
ilnaiduccna
Hi All,
I am at strange.
We have one primary location as DC at Odense
we have one Core switch (4507) here and all servers directly connected to this one.
One MPLS line with 2 MB speed connected to this switch only.
we have many remote locations and those all will be access DC through MPLS line only
Here I want which port utilising more bandwidth or in / out data flow.
NOTE: the core switch does not support to enable #ip flow cache & #ip counters
Is there any other ways how we can get exactly which port how utilizating
I already verified with command #sh int stats but we have to check this pirodically if we want correct figure for particular time frame.
Giuseppe Larosa
Hello Naidu,
on C4500 you can use
sh int summary it provides numbers one line for each port
Example:
sh int summary
*: interface is up
IHQ: pkts in input hold queue IQD: pkts dropped from input queue
OHQ: pkts in output hold queue OQD: pkts dropped from output queue
RXBS: rx rate (bits/sec) RXPS: rx rate (pkts/sec)
TXBS: tx rate (bits/sec) TXPS: tx rate (pkts/sec)
TRTL: throttle count
Interface IHQ IQD OHQ OQD RXBS RXPS TXBS TXPS TRTL
Vlan1 0 0 0 0 0 0 0 0 0
* Vlan301 0 0 0 0 1000 1 1000 1 0
* GigabitEthernet1/1 0 0 0 0 324477000 40299 52306000 20610 0
* GigabitEthernet1/2 0 0 0 0 53000 56 1000 3 0
GigabitEthernet2/1 0 0 0 0 0 0 0 0 0
* GigabitEthernet2/2 0 0 0 0 0 0 0 0 0
* GigabitEthernet2/3 0 0 0 0 16000 8 15000 10 0
* GigabitEthernet2/4 0 0 0 0 0 0 1000 2 0
* GigabitEthernet2/5 0 0 0 0 0 0 4000 5 0
* GigabitEthernet2/6 0 0 0 0 0 0 5000 6 0
* GigabitEthernet2/7 0 0 0 0 0 0 1000 2 0
* GigabitEthernet2/8 0 0 0 0 0 0 0 0 0
* GigabitEthernet2/9 0 0 0 0 9000 10 12000 14 0
Hope to help
Giuseppe
