Switch 4507 issue
mahesh-gohil
Hi all,
I am not able set encapsulation on the gig port of one of my switch as I want to allow only few vlan on any port
Switch: WS-C4507R-E
IOS: 12.2(44)SG1 ((cat4500e-ENTSERVICESK9-M))
Switchport capability:
sh int GigabitEthernet1/10 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: down
Administrative Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
Thanks in advance
--mahesh
Mark Yeates
Level 7
Level 7
mahesh,
It is likely that you have one of the newer linecards that only support 802.1q trunking. Therefore if you have the interface set for " switchport mode trunk" it will only operate with dot1q trunks.
HTH,
Mark
Mark Yeates
Level 7
Level 7
mahesh,
HTH,
Mark
