11-25-2010 05:00 AM - edited 03-06-2019 02:13 PM
92706128 packets input, 60600536475 bytes, 0 no buffer
Received 61625 broadcasts, 0 runts, 11064233 giants, 0 throttles
11064234 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
96315547 packets output, 39767932838 bytes, 0 underruns
0 lost carrier, 0 no carrier
i have a question about " show interface " output information .
1) 11064234 input errors
2) 11064233 giants
are the two output information normal states ???
Solved! Go to Solution.
11-26-2010 05:38 AM
If application sending packets with df bit set then mtu definately increases counter for giants. you can configure maximum mtu supported on
interface
in addtion for interface errors problem could be speed/duplex mismatch or physical layer problem (cable issue)
Hope this helps
Mahesh
11-25-2010 05:34 AM
It is not normal.
> error: Could be issue with loose cable or faulty connected hardware
> giant: remote device is sending larger sized packets
just pasting below info. for mode clarity
Hope this helps
Mahesh
11-25-2010 07:38 AM
this is my configuration in the interface gigabitethernet .....
interface GigabitEthernet8/2
no ip address
media-type rj45
speed 100
switchport
switchport mode trunk
end
my interface connect to optical-to-electrical transducer .
11-25-2010 07:22 PM
hi mehesh :
i also feel not good state . but i don't konw how to sovle this trouble.
i think it's MTU promble .... but , if i need to change our side mtu 15xx . or ask huawei , what's the interface MTU number..
but MTU is 1500 in the ethernet..
11-26-2010 05:38 AM
interface
Hope this helps
Mahesh
