Switch 9300 Chassis 0 reloading, reason - Non participant detected
magedsayed
Hi everyone.
I need a help... I have a Switch Cisco 9300 and this switch isn't booting up correctly and continues reloading
I tried to boot up from emergency-install but problem still exist.
And here it is the output
Dec 13 10:55:30.961: %PMAN-5-EXITACTION: C0/0: pvp: Process manager is exiting:
Both links down, not waiting for other switches
Switch number is 2
Dec 13 10:55:38.500: %PMAN-3-PROCHOLDDOWN: R0/0: pman: The process platform_mgr has been helddown (rc 134)
Dec 13 10:55:39.278: %PMAN-0-PROCFAILCRIT: R0/0: pvp: A critical process platform_mgr has failed (rc 134)
Dec 13 10:55:39.326: %PMAN-3-RELOAD_RP: R0/0: pvp: Reloading: Switch will be reloaded
Chassis 2 reloading, reason - Non participant detected
Dec 13 10:55:41.548: %PMAN-5-EXITACTION: F0/0: pvp: Process manager is exiting: reload fp action requested
Dec 13 10:55:42.891: %PMAN-5-Dec 13 10:55:43.621: %PMAN-3-PROCESS_NOTIFICATION: R0/0: pvp: System report /crashinfo/system-report_local_20201213-105543-Universal.tar.gz (size: 1800 KB) generated
marce1000
               https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvn29387/?referring_site=ss&dtid=osscdc000283
  M.
Reza Sharifi
If this is a new switch and you have a support contract for it, open a ticket with Cisco. If they are not able to fix it, RMA the switch.
mark27
Same problem here.
The 9300 was part of a stack of 7, two stacking cables where intermittently faulty so this switch lost communication with the stack while powered up and is now in a boot loop.
[2021-11-30 09:31:01.685] Nov 30 10:33:20.753: %PMAN-3-PROCHOLDDOWN: R0/0: The process cmand has been helddown (rc 134)
[2021-11-30 09:31:01.779] Nov 30 10:33:20.835: %PMAN-0-PROCFAILCRIT: R0/0: pvp: A critical process cmand has failed (rc 134)
[2021-11-30 09:31:01.890] Nov 30 10:33:20.892: %PMAN-3-RELOAD_RP: R0/0: pvp: Reloading: Switch will be reloaded
[2021-11-30 09:31:01.968]
[2021-11-30 09:31:01.968] Chassis 0 reloading, reason - Non participant detected
[2021-11-30 09:31:02.030] reload fp action requested
[2021-11-30 09:31:03.609] Critical process cmand fault on rp_0_0 (rc=134)
[2021-11-30 09:31:04.557] Nov 30 10:33:23.632: %PMAN-3-PROCESS_NOTIFICATION: R0/0: pvp: System report /crashinfo/system-report_local_20211130-103323-Universal.tar.gz (size: 2202 KB) generated
[2021-11-30 09:31:04.744]
[2021-11-30 09:31:04.760]
[2021-11-30 09:31:10.977]
[2021-11-30 09:31:10.992] Initializing Hardware...
If anyone knows of a fix that would be useful if not I can send it back.
           - Install latest advisory software release on it
M.
