Switch automatic disconnect all interface connection In less than five seconds and back worked again
hunterman
Hello everyone,
I have switch cisco model 2960x with Version 15.2(6r)E, All the time ago the switch worked as fine without any any problem, Today i have issue and the issue happen less than five seconds and back worked again and since that the switch automatic disconnect all interface connection,
Switch#sh pro cpu
CPU utilization for five seconds: 44%/1%; one minute: 42%; five minutes: 43%
Whats the problem?
THANKS
Mark Malone
not possible to tell with the information provided
Do you have logs from the time of the event from switch or syslog ?
show loggs
was there a spanning tree issue at layer 2 ?
show spanning-tree detail | inc ieee|occurr|from|is exec
Problem solved without changes in configuration, But if the issue back again i will replay here,
Thank you for your replay
