Switch C9300-48UXM - license upgrade via smart reservation command
FrancisJr
Hi there,
Just a quick question, after changing the license level (network-essentials to Network-Advantage) on the cisco C9300-48UXM using the "smart reservation" method, does it need to be rebooted or will the new license take effect without a reboot?
for reference, switch is on production.
Thanks in advance
Hi @FrancisJr
 License install/upgrade always requires a reload. When you apply the command to change the license from Essential to Advanced, they will one information saying
 License level next rebood Advantage
Hi @FrancisJr
FrancisJr
Many thanks Flavio
