Switch Capability question / buying help
David Imrie
I'm currently doing an accademic study regarding jitter and latency on 100mbps ethernet.
I want to perform some experiments where i can play with the queueing system on the switch in as finite detail as possible.
I will be running up to 4 PC's at up to 100% utilisation
There are numourous 2nd hand switches on e-bay for aprox £30 i beleive would be suitable.
I was just wondering if anyone had any guidance on specific models or IOS versions and their capabilityies in this area.
singhaam007
Level 3
Level 3
Hi David,
i think  12.2(55)SE3           C2960-LANBASEK9-M will be good for your lab. or its depend on you what you want to use.
2960 are quit good for home labs and samll business.
here is doc for qos.
hope this will help you.
please rate if this helps.
thanks
