Switch Catalyst 3560G Web Interface Problem
fabienfs
Level 2
Level 2
I have a problem with my Cisco Catalyst 3560G switch. The web interface does not work (I tried IE11, IE6, Chrome, Firefox and Safari).
There is only displayed icons but no text :
To try to solve the problem, I've updated the switch to its latest IOS version (from 12.2(55)SE7 to 12.2(55)SE9). But the problem persists
WS-C3560G-48TS     12.2(55)SE9           C3560-IPBASEK9-M
In the configuration, the web server is enabled:
ip http server
ip http secure-server
What can I do?
Best Regards,
Fabien
26 Replies 26
If you've tried different browsers then I would recommend try a different machine.
I tried with another machine, but without success.
But I think the problem is the other. Because I also have a Cisco Catalyst 2960 older, and even if it shows the same error messages, I know still continue :
On the Catalyst 3560, error messages are not displayed correctly even... 😕
Ok, you are using IE.  Try Chrome or Firefox.
I tried in IE, Chrome, Firefox & Safari
Dear  Fabien,
send me the output for the following commands
sh dir
sh runn
sh startup configu
sh boot
***try to reload the switch and check ,
BR
SYED
Dear Syed,
I rebooted the switch.
Here are the results of commands: http://pastebin.com/kDs3t3Yz
thanks
Dear Fabien,
close to solution , check your first post pic and second post pic
try to check on win 7 32. bit
and see the attached file
try it out and update
rete it if help full
BR
SYED
All one has done before, I understand. But here, it's impossible. I do not have any pc 32-bit.
There is no way to make this web interface on a latest version of Windows x64.
It's still very restricitif their web interface. Change pc just to access the Cisco web interface, it makes no sense.. ;-(
what Operating System you are using
Windows 8.1 x64
ihaag
Community Member
Has there been a resolution at all to this problem? Thanks
marving
Community Member
same issue on 7/32 and 64, either FF than IE.
left menu dont work.
workaround: install and use cisco network assistant
