05-15-2007 09:49 AM - edited 03-05-2019 04:05 PM
Imagine I need to make a switch available to accomodate communications for server-to-server "private" networks, which are used between servers in order to control heartbeats, load balancing, etc.
Currently I have in place a Cisco 24x port hub. I am assessing what type of Cisco switch should be a good replacement for this. My understanding is that this type of NIC communication requires minimal bandwidth.
Please suggest a switch for this. It requires no fancy Layer 3 feature.
Solved! Go to Solution.
05-15-2007 09:53 AM
Hi Friend,
2960 will best serve your requirement. It comes in different models and port density.
Have a look at this link
http://www.cisco.com/en/US/products/ps6406/index.html
Ankur
*Pls rate all helpfull post
05-15-2007 09:53 AM
Hi Friend,
Ankur
