switch-HP restart - urgent
ilnaiduccna
Hi Experts,
I have one HP-switch was getting reboot and the users are getting so much inconveniency. So the challenge is I have to resolve this issue with in early stage.
So Experts can anybody please investigate the firmaware version of this switch and if there are any updated patches which can be applied
Bellow is the info about show version, up-time and logs.
Hp-switch# sh ver
Image stamp: /sw/code/build/fish(mf_v10_fishp)
May 11 2007 10:06:39
H.10.38
575
Boot Image: Primary
Hp-switch# sh uptime
0001:11:17:44.07
Hp-switch# sh log
Keys: W=Warning I=Information
M=Major D=Debug
---- Event Log listing: Events Since Boot ----
M 01/01/90 00:00:06 sys: 'System reboot due to Power Failure'
I 01/01/90 00:00:06 system: --------------------------------------------------
I 01/01/90 00:00:06 system: System went down without saving crash information
I 01/01/90 00:00:26 lacp: Passive Dynamic LACP enabled on all ports
I 01/01/90 00:00:26 udpf: DHCP relay agent feature enabled
I 01/01/90 00:25:51 ports: port 14 is now on-line
I 01/01/90 00:26:01 ports: port 14 is now off-line
I 01/01/90 00:26:03 ports: port 14 is Blocked by LACP
I 01/01/90 00:26:06 ports: port 14 is now on-line
W 01/01/90 00:48:05 FFI: port 1 Duplex Mismatch. Reconfig port to Full Duplex.
W 01/01/90 00:48:05 FFI: port 1-Excessive late collisions.
W 01/01/90 01:00:13 FFI: port 1 Duplex Mismatch. Reconfig port to Full Duplex.
W 01/01/90 01:00:13 FFI: port 1-Excessive late collisions.
W 01/01/90 01:15:17 FFI: port 1 Duplex Mismatch. Reconfig port to Full Duplex.
alexander76
hello,
guess you have a 26xx switch.
the newest firmware is 10.67!
copy this firmware first to primary - afterwards to secondary flash.
then you should remove lacp from all access ports: int 1-48 no lacp, since this is not needed in your lan. you have excessive late collisions on port 1 - which is probably a duplex missmatch an indicates that maybe there is a cisco device on the other side - you should configure both side on 100-full. dont let them negotiate!!
this is a known issue with this manufacturer.
you'll get the new firmware at no cost at manufacturers www-site.
hope this helps, greetz from germany ;)
Thanks for your great information, it was really help me.
Can you just suggest on the comman hardware requirements to upgrade new firmware (10.67!)
Thanks in advance,
Naidu :-)
