Switch MAC address questions
ohalnet53
a layer 2 catalyst switch with 24 10/100 port like 2960,
1- this guy has 24 mac addresses for each physical layer 2 interfaces
and
the switch itself has one independent MAC address right?
2- if that is right, which MAC address is the visible one to the PCs? MAC address of the port PC is connected to or the MAC address of the switch?
3- if we create 3 vlans with 3 ip addresses for each vlan, do we get 3 mac addresses?
I assume answers to above question will not change on layer 3 switches.
tx for helping
Richard Burts
1) The switch will have a MAC address for each interface. There is not an independent MAC for the switch.
2) The MAC that is visible to the PC is the MAC for the interface.
3) No matter how many VLANs you create, or how many IP addresses you assign to the VLAN interface it does not change the number of MAC addresses or the way that the MAC is used.
It would not change if it were a layer 3 switch.
Rick
Rick
tx Rick.
so there isn't such a thing as switch's MAC address. it is Port's MAC address.
but,
'show spanning-tree command' shows MAC address of the root bridge.
all switches within the network shows the same MAC address as the MAC address of the root bridge. altought those switches are connected to root switch through different ports.
i am little confused.
tx for helping
for spanning tree purposes there are other MAC addresses found on the switch, besides the port MACs.
There is a discussion here at
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Career%20Certifications&topic=Training&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dd9fb71
about where a switch takes MAC addresses for spanning tree, which should answer all your questions.
Hope this helps! Please rate all posts.
Regards, Martin
