Switch not Sending packets
jerendon74
Switch in question is 3850-24S
Network is a 10.8.0.0/22
In summary packets are being received from a firewall directly connected to Gig1/0/6. Packets should be egressing Gig1/0/5 to switch downstream and eventually to a server but isn't from what I can see.
Data flow:
Firewall -> Switch -> Switch -> Switch -> Server
The first switch is the switch I am troubleshooting.
Firewall is a Palo Alto 3220 using eth1/3.812 and is tagged as such, IP is 10.8.0.1. In the subinterface I configured it to use a static arp with the IP and MAC of the server I am trying to reach.
In the switch Vlan 812 is configured with x.x.0.2 as its IP address. Vlan 812 is assigned to Gig1/0/6 and configured as an access port.
Gig1/0/5 is configured as a trunk and has other VLANs assigned to it as well.
I can ping from the switch to the server successfully. When I try to ping from the firewall to the server, its unsuccessful and  packets are only received at Gig1/0/6. In the detail view of the packet capture I verified source IP & MAC were correct as well as destination IP & MAC.  I'd expect to see packets egress Gig1/0/5 but theres nothing showing that in the packet capture.
When doing a packet capture on Gig1/0/6 it states x amount of packets received and x amount of packets transmitted. I am not seeing where those are being received. Is there a way to see in the packet capture where those are sent?
In regards to the mac address table, I statically input the mac address with this command in config
mac address-table static x.x.x vlan 812 int gig1/0/5
The same happened when trying to ping. No packets were egressed out of 1/0/5
5 Replies 5
post the full running configuration of the switch...
Unfortunately I cannot upload the config file. The system is a closed environment so I am unable to take anything off.
I am willing to hand jam sections of the config that you'd be interested in seeing.
Harold Ritter
Hi @jerendon74 ,
This is a misconfiguration. The FW is configured for trunking and the switch interface (gi1/0/6) is configured for access. You need to fix this.
Sorry for the late response.
I made the change and am not getting past the switch still.
There were some other issues as well in my switch config, which included the IP address in the VLAN and some STP settings on the interface connected to the firewall. Thank you for your feedback!
