Switch Port config connected to Cisco ATA Switch
mahesh18
Level 6
Level 6
Hi Everyone,
I need to confirm config of switch port that connects to Cisco ATA switch for fax lines.
SW1        Cisco VG 202XM
int fa0/1---------------------------------------------------------------------connects to Cisco ATA switch  VG 202XM  port fa0/1-------------
switchport mode access
switchport voice vlan 10
Need to confirm do we need switchport access vlan and spanning tree portfast config here?
Also should we use cross over or straight through cable for this?
Mahesh
Reza Sharifi
Hi Mahesh,
Your voice vlan config looks correct.  As for the crossover cable, I think you can simply use a straight through cable to connect to ATA.It was a long time ago I worked with ATAs.
Reza Sharifi
Hi Mahesh,
Many thanks Reza.
Mahesh
