Switch replacement procedure 3560G to 3750X
adi822001
                   Hello  Cisco experts,
My company will replace two 3560G (HSRP active Standby) with 2 3750X ( will be stacked)  switches in the near future.
I need to make a switch replacement procedure ( starting from removing the 3560s  until the 3750x are put online, but i think i need your advice.
I have  google it, searched cisco website documents, various forums but i couldnt find something to suit my needs.
My approach will be to
1. backup the standby  3560 config (traffi will flow through the active 3560) .
2. remove the plug of 3560and put in one 3750x. Configure 3750x to accept traffic and to be the  stack master.
3. backup the config on the remaining 3560 and remove it.
4. Plug in the second 3750x
5. Configure it as stack member.
Can you please advise me , point me to any document that shows a step by step procedure when replacing a cisco ( moving fr one mode to another)
Thank you in advance for your help.
PS :Excuse my English. I am japanese. :d
エイドリアン
3 Accepted Solutions
Leo Laohoo
Have you purchased the 3750X yet?  If not, go for the 3850.  The exact corresponding model of the 3850 is priced THE SAME but with greater performance.
1.  Because you can stack the 3750X/3850, there's no need to configure HSRP.
2.  You first configure the stack master with the config above.  But your interface naming convention will have to change.
3750/3850 follow the same interface naming syntax:  Gigabit //Port
So you re-compile your interface configuration for the first switch as GigabitEthernet 1/0/24.  The second switch would be GigabitEthernet 2/0/12.
Here's a good proceedure to install a stack of 3750X:
1.  DO NOT APPLY POWER to all switches;
2.  Install the Master switch;
3.  Power up the Master switch;
4.  Configure master priority using the command "switch 1 priority 15";
5.  Configure the succeeding switch members using the command "switch X provisioning <3750 model number>";
6.  Configure the switch stack;
7.  Attach the rest of the switch members;
8.  DO NOT provide power to the stack members;
9.  Attach stacking cable;
10.  Power up the stack member ONE AT A TIME and ACCORDING to the order
11.  Put 15 seconds interval before powering up the next switch member.
Before I install the 3750 stack, I would need to archive and backup the 3560Gs and then unplug them.
I don't think this is possible.  At the end of the day, you need to MOVE your links from the 3560G to the 3750 stack.  How you can achieve this without any "disruptions" is beyond me.
12 Replies 12
JohnTylerPearce
Level 7
Level 7
Adrian,
First, I understand that these two switches (3560Gs) are running HSRP. How do these switches fit in your network?
Second, you can go ahead and power on and configure the 3750 stack, so there is very minimal downtime, when you get ready to do a switchover.
Thanks for replying John,
I am pasting the two 3560G sh run :
Vlan 10 --- WAN, Vlan 20 FW; NET , Vlan 40 DMZ  , VLAN 50 Vmware,
Is there a written procedure when transition between switches ?
HSRP Active
version 12.2
interface GigabitEthernet0/1
switchport access vlan 10
switchport mode access
spanning-tree portfast
interface GigabitEthernet0/2
interface GigabitEthernet0/3
switchport access vlan 20
interface GigabitEthernet0/4
interface GigabitEthernet0/5
switchport access vlan 30
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
switchport access vlan 50
interface GigabitEthernet0/10
interface GigabitEthernet0/11
switchport access vlan 60
interface GigabitEthernet0/12
interface GigabitEthernet0/13
switchport access vlan 70
interface GigabitEthernet0/14
interface GigabitEthernet0/15
switchport access vlan 80
interface GigabitEthernet0/16
interface GigabitEthernet0/17
switchport access vlan 90
interface GigabitEthernet0/18
interface GigabitEthernet0/19
switchport access vlan 100
interface GigabitEthernet0/20
interface GigabitEthernet0/21
speed 100
duplex full
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
switchport trunk allowed vlan 10,20,30,50,60,70,80,90,100
switchport mode trunk
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1
ip address 192.168.1.201 255.255.255.0
no ip redirects
standby 0 ip 192.168.1.20
standby 0 priority 105
standby 0 preempt
interface Vlan10
ip address 172.20.10.2 255.255.255.0
no ip redirects
standby 1 ip 172.20.10.1
standby 1 priority 105
standby 1 preempt
interface Vlan20
ip address 172.20.20.2 255.255.255.0
no ip redirects
standby 2 ip 172.20.20.1
standby 2 priority 105
standby 2 preempt
interface Vlan30
ip address 172.20.30.2 255.255.255.0
no ip redirects
standby 3 ip 172.20.30.1
standby 3 priority 105
standby 3 preempt
interface Vlan40
ip address 172.20.40.2 255.255.255.0
no ip redirects
standby 4 ip 172.20.40.1
standby 4 priority 105
standby 4 preempt
interface Vlan50
ip address 172.20.50.2 255.255.255.0
no ip redirects
standby 5 ip 172.20.50.1
standby 5 priority 105
standby 5 preempt
interface Vlan60
ip address 172.20.60.2 255.255.255.0
no ip redirects
standby 6 ip 172.20.60.1
standby 6 priority 105
standby 6 preempt
interface Vlan70
ip address 172.20.70.2 255.255.255.0
no ip redirects
standby 7 ip 172.20.70.1
standby 7 priority 105
standby 7 preempt
interface Vlan80
ip address 172.20.80.2 255.255.255.0
no ip redirects
standby 8 ip 172.20.80.1
standby 8 priority 105
standby 8 preempt
interface Vlan90
ip address 172.20.90.2 255.255.255.0
no ip redirects
standby 9 ip 172.20.90.1
standby 9 priority 105
standby 9 preempt
interface Vlan100
ip address 172.20.100.2 255.255.255.0
no ip redirects
standby 10 ip 172.20.100.1
standby 10 priority 105
standby 10 preempt
Second
version 12.2
interface Vlan1
ip address 192.168.1.202 255.255.255.0
no ip redirects
standby ip 192.168.1.20
standby preempt
interface Vlan10
ip address 172.20.10.3 255.255.255.0
no ip redirects
standby 1 preempt
interface Vlan20
ip address 172.20.20.3 255.255.255.0
no ip redirects
standby 2 preempt
interface Vlan30
ip address 172.20.30.3 255.255.255.0
no ip redirects
standby 3 preempt
interface Vlan40
ip address 172.20.40.3 255.255.255.0
no ip redirects
standby 4 preempt
interface Vlan50
ip address 172.20.50.3 255.255.255.0
no ip redirects
standby 5 preempt
interface Vlan60
ip address 172.20.60.3 255.255.255.0
standby 6 preempt
interface Vlan70
ip address 172.20.70.3 255.255.255.0
no ip redirects
standby 7 preempt
interface Vlan80
ip address 172.20.80.3 255.255.255.0
no ip redirects
standby 8 preempt
interface Vlan90
ip address 172.20.90.3 255.255.255.0
no ip redirects
standby 9 preempt
interface Vlan100
ip address 172.20.100.3 255.255.255.0
no ip redirects
standby 10 preempt
Thsnks
エイドリアン
Leo Laohoo
Thanks for your reply Leo,
The company has purchased the 3750x switches.
Can you guide me with  step-by-step instructions ?
My opinion
1. Remove 3560G switch
a) Archive backup before remove the 3560 switch we need to save its configuration; b) Mark the labels on the connect switch cables and record each corresponding switch port;
c) Shutdown, power off and unplug all the connecting cables;
d) Remove the switch out of Cabinet
2 Install 3750x Switch
a) Configure  Switch;
b) Put  switch in cabinet;
c) In accordance with the original line corresponds to the original plan plugged;
d) Test connection 1
エイドリアン
Hi Leo,
Thanks for your detailed procedure.
It is very helpful.
One more query.
Can I do the switchover live without disrupting the traffic? Or a maintenance window is mandatory?
Now the 2 3560G are in production.
Thank you
エイドリアン
Thank you Leo,
I got the point now.
Thank you for your great support.
エイドリアン
Adrian,
As suggested you get MW schedule to perform this action as this would cause the distruption on your network. Reason behine that you are going to replace th switches and makeing the new as stack.
Hope all your query's are answered by leo may I request you to kindly rate his posts and mark this thread as answered so that other be benefited with this thread in future.
Thanks for your understanding.
REgards
Inayath
*Plz rate all usefull posts and mark the thread as answered if solution been provided to you.
Thanks for the ratings, Adrian.
Another thing, Adrian.
If you are in good terms with your Cisco account team, you could (potentially) get them to replace your 3750X with 3850 at no cost.
Thanks Leo,
I will try communicate this to my bosses but japanese companies are very strict when changing something.
Thank you again for your great support.
エイドリアン
エイドリアン
