switch stack trap
iec1128759
help with a switch stack in which I have 3 in stack but swich is monitored with a single ip need to know if there is any trap that tells me there is a problem with any of the switch in stack
Thanks for your attention
Richard Michael
Unfortunately there is no such way we can assign the IP address to each switch in the stack saparately.
There is a way to poll each switch in the stack using SNMP, the way to do it is to use the CISCO-STACKWISE-MIB to generate the traps.
We will need to add the following command to the switch:
"snmp-server enable traps stackwise"
After that you will be able to receive traps for cswStackMemberRemoved(.1.3.6.1.4.1.9.9.500.0.0.6) the trap you inform you of a missing switch in the stack.
Other useful stackwise OID's are:
  cswStackPortChange(.1.3.6.1.4.1.9.9.500.0.0.1)
  cswStackNewMaster(.1.3.6.1.4.1.9.9.500.0.0.2)
  cswStackMismatch(.1.3.6.1.4.1.9.9.500.0.0.3)
  cswStackRingRedundant(.1.3.6.1.4.1.9.9.500.0.0.4)
Ricky Micky
*Rate Useful posts
