switch troubleshootin
hiprecy123
i cant ping any of my switches in the network or  make pings from it    when am using PT but it started after is intalling its version 6.3
but i can ping  hosts connected to it  check my topology of my network in  the attachement ...i ned help guys,....and  my routing protocol is ospf
SWITCH!#sh r
Building configuration...
Current configuration : 1156 bytes
version 12.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname SWITCH!
enable password cisco
username swizzy secret 5 $1$mERr$hx5rVt7rPNoS4wqbXKX7m0
spanning-tree mode pvst
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
ip address 192.168.1.2 255.255.255.0
line con 0
password cisco
login
exec-timeout 30 0
line vty 0 4
exec-timeout 30 0
password cisco
login local
line vty 5 15
login
end
SWITCH!#
Mark Malone
You should have default gateway on your switch above so traffic knows how to get back to it , you can ping devices under same vlan as routing is not required it uses arp at layer 2.
