01-31-2014 09:28 AM - edited 03-07-2019 05:56 PM
What will be the result of having these two commands defined on trunk
Switch(Config-if)# switchport trunk native vlan 500
Switch(Config-if)# switchport trunk allowed vlan remove 500
01-31-2014 09:35 AM
Traffic from vlan 500 will be sent untagged .
01-31-2014 09:38 AM
The first command would send traffic untagged over vlan 500, but the second command removes vlan 500 from the trunk, so I think you would lose traffic for anything using vlan 500....
HTH,
John
*** Please rate all useful posts ***
01-31-2014 09:45 AM
Zafar
I agree with John, basically vlan 500 will not be allowed across the trunk link.
I assume the reasoning behind the configuration is that all vlans sent across the link should be tagged.
Jon
