switch trunking
korbenda11as
in trunking, can i use layer 2 and 3 just to trunk? or it should be the same type of switches? thanks...
6 Replies 6
mahmoodmkl
Level 7
Level 7
No u can use any switch for trunking as its a layer 2 funtion.
Mahmood
thanks, just a follow up question. For inter VLAN, should both layer 3 switches enable routing proto (.e.g RIP, OSPF). thanks
For intervlan routing to occur u need to create SVI's for each vlan on u r layer 3 switch.eg
int vlan 1
ip address a.b.c.d subnetmask
like this u have to create for each vlan.
there is no need to enable any dynamic routing protocol as all the networks will be directly connected.
Mahmood
In addition to Mahmood's post, on a Layer 3 switch you have to use "IP routing " to enable inter-vlan routing. For example
Conf t
Ip routing
int vlan 1
ip address x.x.x.x a.a.a.a
no shut
int vlan 2
ip address y.y.y.y a.a.a.a
HTH,
-amit singh
thanks a million!
thanks a million!
