04-22-2022 03:48 AM
Could use some advise. Looking to upgrade a small office network, currently using 2 CE520 24port switches since around 2009
Having upgraded the rest of the network we are now looking to replace these switches with something that supports 1000MB ports. The network consists of around 15 PCs/Polycom phones upstairs and 6 downstairs (plus usual printers/ scanners/wifi)
The switches are linked to an ASA router and then to BT fibre.
What would people recommend for this solution, either current or older stock
Ben
04-22-2022 03:52 AM
If this Layer 2 Look for
Cat 1000 or Cat 9200
If you looking Layer3 and more Functionalities Look for
Cat 9300
You looking Small business below tool help you :
https://www.cisco.com/c/en_uk/solutions/small-business/selector-tool.html?ccid=cc001566
04-22-2022 04:01 AM
Hi BB,
Thanks for the reply. I'm getting slightly confused as to what is termed a Layer 2/Layer 3 switch. The PCs attach directly to this switch and the Switch is then connected to ASA gateway/firewall.
I'll take a look at the link you have provided.
Ben
Ben
04-22-2022 05:33 AM
As per description you mentioned its Pure Layer 2, Cat 9200 is good enough as i see the requirement.
But Cat 9300 my Favour in case in the feature you need more features.
check some compare - (if the price compare, very marginal from your vendor Cat 9200 to Cat 9300, then if you have budget go for Cat 9300).
https://askanydifference.com/difference-between-cisco-c9200-and-c9300/
04-22-2022 04:19 AM
The currectly most used switch for Access with 1 Giga I´d say is 9300. Or maybe Cisco 350 Series Switches.
