Switch WS-C2960G-48-TC-L can't booting IOS
Hello Experts, I have problem with my Switch 2960G
LED on front switch is on, but when I console the IOS doesn't booting...
And, I can't rommon this switch,
please give me solution to solve this problem.
5 Replies 5
Mukesh Kumar
Level 3
Level 3
Hello Dani Royman Simanjuntak
When you access your switch by using putty there is default console speed that is 9600 bps. If you are not able to access your switch by using the default console speed you can try with different console speeds like 4800, 1200, 2400, 19200, 38400, 57600, and 115200 baud.
Mukesh Kumar
Network Engineer
Spooster IT Services
I have set baud rate 9600 and try another baud rate but not work,
I have install that switch and running properly two weeks ago, I think this problem not about console  .
Have you tried some different terminal emulator like tera term, secure crt, hyper terminal, etc.?
Have you checked the COM port of the pc and console cable?
Mukesh Kumar
Network Engineer
Hello Mukesh Kumar,
I have try with Teraterm, SecureCRT, but not working..
Have you connected the same console cable, emulator and PC on some other router/switch?
May be there will be a fault in the console cable or COM port of the pc.
Mukesh Kumar
Network Engineer
