Switch WS-C3750X-24 Auto Restart
roeurmchanna
Dear Cisco Team,
My switch-02 mostly auto restart which running as switch stack with switch -01.
I checking found that the Last reset from power-on
Please share me the solution.
SFSW-B#sho switch stack-ports summ
Switch#/  Stack   Neighbor   Cable    Link   Link   Sync      #         In
 Port#     Port              Length    OK   Active   OK    Changes   Loopback
          Status                                          To LinkOK
  1/1     OK         2      3 m       Yes    Yes    Yes       30        No
  1/2     OK         2      3 m       Yes    Yes    Yes       30        No
  2/1     OK         1      3 m       Yes    Yes    Yes        1        No
  2/2     OK         1      3 m       Yes    Yes    Yes        1        No
SFSW-B#sh version
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 02-Dec-10 06:08 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
SE-B1-SVRM-SFSW-B uptime is 6 weeks, 6 days, 7 hours, 28 minutes
System restarted at 01:14:45 UTC Sun Feb 8 2015
System image file is "flash:/c3750e-universalk9-mz.122-55.SE1/c3750e-universalk9-mz.122-55.SE1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3750X-24 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID FDO1636R2EG
2 Virtual Ethernet interfaces
1 FastEthernet interface
56 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 6C:20:56:66:55:00
Motherboard assembly number     : 73-12530-08
Motherboard serial number       : FDO16361JPB
Model revision number           : A0
Motherboard revision number     : A0
Model number                    : WS-C3750X-24T-S
Daughterboard assembly number   : 800-32727-03
Daughterboard serial number     : FDO16360SLN
System serial number            : FDO1636R2EG
Top Assembly Part Number        : 800-31327-07
Top Assembly Revision Number    : A0
Version ID                      : V04
CLEI Code Number                : COMJV00ARD
Hardware Board Revision Number  : 0x04
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3750X-24       12.2(55)SE1           C3750E-UNIVERSALK9-M
     2 30    WS-C3750X-24       12.2(55)SE1           C3750E-UNIVERSALK9-M
Switch 02
Switch Uptime                   : 8 hours, 6 minutes
Base ethernet MAC Address       : C8:9C:1D:E0:F5:80
Motherboard assembly number     : 73-12530-05
Motherboard serial number       : FDO15070S7P
Daughterboard assembly number   : 800-32727-01
Daughterboard serial number     : FDO1505182W
System serial number            : FDO1506R1CL
Top assembly part number        : 800-31327-02
Top assembly revision number    : A0
Version ID                      : V02
CLEI Code Number                : COMJV00ARB
License Level                   : ipbase
License Type                    : Permanent
Next reboot licensing Level     : ipbase
0 Replies 0
