09-01-2020 01:33 PM
Hi everyone
I have a pair of stacked 3850 switches.
The stacked switches have two uplinks (Tengig1 /1/1 and Ten2 /1/4) in port-channel.
Port Te1 /1/1 fails to activate in port-channel.
The release used is cat3k_caa-universalk9.16.12.03a.SPA.bin
(install mode)
below the show interface Ten1 /1/1
swccopn0b2 # show interface te1 /1/1
TenGigabitEthernet1 /1/1 is down, line protocol is down (notconnect)
Hardware is not present
Hardware is Ten Gigabit Ethernet, address is cc98.916b.9535 (bia cc98.916b.9535)
Description: sw-ccocore te1 / 0/25
MTU 1500 bytes, BW 10000000 Kbit / sec, DLY 10 usec,
Keepalive not set
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size / max / drops / flushes); Total output drops: 0
Queuing strategy: fifo
Output queue: 0/40 (size / max)
5 minute input rate 0 bits / sec, 0 packets / sec
5 minute output rate 0 bits / sec, 0 packets / sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
Output 0 broadcasts (0 multicasts)
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
I've noted Hardware is not present but how I can solve it ?
Thanks in advance for any help
Fabrizio
Solved! Go to Solution.
09-03-2020 01:43 AM
Hi all
I solved the problem.
looking better the uplink module (Uplink Module 1", DESCR: "2x1G 2x10G Uplink Module"),
I saw that there are four ports for each switch :
Gig1/1/1, Gig1/1/2, Gig/Ten1/1/3, Gig/Ten1/1/4
Gig2/1/1, Gig2/1/2, Gig/Ten2/1/3, Gig/Ten2/1/4
It seems that it is not possible to form a port-channel, mixing port Gig and Ten/Gig.
For example I did a port-channel with Gig1/1/1 and Gig2/1/1 or Gig/Ten1/1/4 or Gig/Ten2/1/4.
That's my experience
Anyway thank's at all and have a nice day
09-01-2020 01:40 PM
Is this a cisco SFP, what is speed and SFP model information can provide here.
09-01-2020 02:00 PM
Hi Balaji
Here are the information required :
Administrative Speed: 1000
Administrative Duplex: full
Administrative Auto-MDIX: on
Administrative Power Inline: N/A
Operational Speed: 1000
Operational Duplex: full
Operational Auto-MDIX: on
Media Type: 1000BaseSX SFP
Thank's
09-01-2020 02:07 PM
i am confused with the information, you mentioned one port ten 1/1/1 and ten 2/1/4
but as per your recent post, you provided gi 1/1/1 and ten 2/1/4
can you post
show switch
show interface status
is the SFP you using on uplink cisco brand or any other brand? what is the model of SFP?
09-01-2020 02:30 PM
swccopn0b2#show switch
Switch/Stack Mac Address : cc98.916b.9500 - Local Mac Address
Mac persistency wait time: 4 mins
H/W Current
Switch# Role Mac Address Priority Version State
*1 Active cc98.916b.9500 14 V07 Ready
2 Standby cc98.9139.f100 13 V07 Ready
show interfaces status
Port Name Status Vlan Duplex Speed Type
Gi1/1/1 connected trunk full 1000 1000BaseSX SFP
Te2/1/4 sw-ccocore Te2/0/2 connected trunk full 1000 1000BaseSX SFP
Now I've not brand and sfp model, but as soon as possible I' complete these information.
Anyway I see that there is something wrong in fact interface 1/1/1 seems a Giga and not a Tengiga
Thank's
09-01-2020 03:18 PM
Post the complete output to the following command:
show inventory
09-01-2020 10:14 PM
here is show inventory
swccopn0b2#show inventory
NAME: "c38xx Stack", DESCR: "c38xx Stack"
PID: WS-C3850-48P-E , VID: V07 , SN: FCW2127C18M
NAME: "Switch 1", DESCR: "WS-C3850-48P-E"
NAME: "StackPort1/1", DESCR: "StackPort1/1"
PID: STACK-T1-50CM , VID: V01 , SN: MOC2127A3GF
NAME: "StackPort1/2", DESCR: "StackPort1/2"
PID: STACK-T1-3M , VID: V01 , SN: MOC2128A1A4
NAME: "Switch 1 - Power Supply A", DESCR: "Switch 1 - Power Supply A"
PID: PWR-C1-715WAC , VID: V02 , SN: LIT21222JEF
NAME: "Switch 1 - Power Supply B", DESCR: "Switch 1 - Power Supply B"
PID: PWR-C1-1100WAC , VID: V02 , SN: LIT21224G97
NAME: "Switch 1 FRU Uplink Module 1", DESCR: "2x1G 2x10G Uplink Module"
PID: C3850-NM-2-10G , VID: V01 , SN: FOC21278Y3G
NAME: "Gi1/1/1", DESCR: "1000BaseSX SFP"
PID: , VID: , SN: FNS14350PN2
NAME: "Switch 2", DESCR: "WS-C3850-48P-E"
PID: WS-C3850-48P-E , VID: V07 , SN: FOC2127L41A
NAME: "StackPort2/1", DESCR: "StackPort2/1"
NAME: "StackPort2/2", DESCR: "StackPort2/2"
NAME: "Switch 2 - Power Supply A", DESCR: "Switch 2 - Power Supply A"
PID: PWR-C1-715WAC , VID: V02 , SN: LIT21222JUW
NAME: "Switch 2 - Power Supply B", DESCR: "Switch 2 - Power Supply B"
PID: PWR-C1-1100WAC , VID: V02 , SN: LIT21224FFP
NAME: "Switch 2 FRU Uplink Module 1", DESCR: "2x1G 2x10G Uplink Module"
PID: C3850-NM-2-10G , VID: V01 , SN: FOC21278Y5T
NAME: "Te2/1/4", DESCR: "1000BaseSX SFP"
PID: , VID: , SN: FNS14350PR2
09-03-2020 01:43 AM
Hi all
