Switches Supported with RPS2300
Kimberly Adams
Level 3
Level 3
Hey Everyone,
I know the white papers say that the RPS 2300 supports the 3750-E series and the 3750 series, but we have 3750-G and -X series.  Wanted to make sure that these switches are supported and if we need anything special?
Kimberly
Thanks and Cheers! Kimberly Please remember to rate helpful posts.
Sorry, wasn't here then to see this. Yes, it would be compatible. I do know there are two different RPS power cables, depending on which kind of switch you are connecting to. Unfortunately I don't remember which is which...
Kimberly Adams
Level 3
Level 3
Everyone,
I did happen to find the answer to my question talking to Cisco PSE.  All 3750 series switches are supported with this specific RPS 2300 system.
Just in case someone else is looking for this answer.
Kimberly
Thanks Andrew.
We all can't be here all the time to answer everyone's questions!
Have a good day.
Kimberly
