switching between consoles
tdeganus
I am running IOS on a 6500/sup730 .It is possible to switch between the RP and SP consoles.
You can use the 'remote command' and 'remote login' commands to attach to the SP of the Supervisor or any DFC equipped modules.
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst6500/ios/12.1E/native/command/reference/R1.html#wpxref41123
The SP supports some of the usual 'show' commands, plus other stuff that isn't available on the RP such as test etherchannel:
http://www.cisco.com/en/US/partner/tech/tk389/tk213/technologies_tech_note09186a0080094714.shtml
I can't seem to find a list of supported commands on the SP but I assume '?' still works? I haven't got access to a 6500 to test.
Andy
