Switching
Can we connect PC to a trunk port instead of access port and allow only one vlan
1 ACCEPTED SOLUTION
Rising star
Re: Switching
 - The whyness still stumbles me....
  M.
8 REPLIES 8
VIP Expert
Re: Switching
Yes, as long as the PC is capable of trunking.
Re: Switching
How do we verify if a normal pc is capable of trunking?
Re: Switching
@rakshitsrinivas Hi PC does not understand trunk or access port. But as you have connected your PC to trunk port and want to allow only one VLAN than you need to apply VLAN access list to allow only specific VLAN.
Hope that help.
Krishna
Re: Switching
@KrishnaTiwari8030 Thanks for your reply
so we are applying access list to allow a specific vlan on a trunk link since we want to make a trunk port to allow a specific vlan or desired vlan am i right? correct me if i am wrong?
VIP Expert
Re: Switching
Examination of the NIC driver may indicate such support. (If the PC is designed to be a server, the hardware likely supports VLAN tagging, I believe VM sometimes uses it for different VMs.)
Re: Switching
@Joseph W. Doherty i can give the scenario for example
Normal pc on a trunk port allowing one vlan as desired------switch-----rest of the topology
VIP Expert
Re: Switching
For your example, usually a PC using only one VLAN would use untagged frames, i.e. a switch access port. However, the switch can easily make the port a trunk and limit it to one VLAN. Then the port would expect to use tagged frames. Again, it would be up to the PC whether it can support that.
Rising star
Re: Switching
  M.
Content for Community-Ad
July's Community Spotlight Awards
