switchport protected
Ibrahim Jamil
Level 6
Level 6
i want to prevent to servers from talk to each others .srv-dc-1:X.X.X.X connect to SW1 on port g0/0 while srv-dc-2 :Y.Y.Y.Y connect to SW10 on port g0/0.
is it good to configure switchport protected on ports where these servers connected in order to achieve this scenario, i don't want to use acl
thanks
Ibrahim
Mohamed Sobair
Level 7
Level 7
This command is efficient ONLY on the Same Switch (Blocking communication between ports on the Same Switch).
In Your Case, Since there are Two different interconnected SWs, Use (Private VLans with VTPv3)  Or Use (VLAN MAP ACL).
Mohamed
Hi Mohamed
thanks for ur reply
Pls can you post me a sample for what you have suggested
thanks
ibrahim
