'switchport trunk allowed vlan except'
syjeon
Hi All.
I'm just worried that above subjet command will be used in first time in our switching environment.
Basically, all of vlans are allowing in x-over trunk interface. Btw, we don't want to allow specific vlan a, vlan b.
the work procedure will be happening on primary device as following
primary)
inteface port-channel x/x
switchport trunk allwoed vlan except vlan a, b
secondary)
interface port-channel x/x
switchport mode trunk
  -- allowed vlan
once primary device is done, and then we will move to secondary device to modify.
primary)
secondary)
STP is defined basically. so, above work procedure will be safe? it's our core device so I guess it will be ok. but, I would like to get knowhow to avoid unexpected situation during change window.
Thanks.
0 Replies 0
