Showing results forĀ
Search instead forĀ
Did you mean:Ā
switchport trunk encapsulation dot1q Fails on a 4900m
cbulleri
I'm setting up a new 4900m running  cat4500e-ipbase-mz.122-53.SG5.bin.
I'm attempting to create Port-Channels as a Trunk for uplink to a 4503 running cat4500-ipbase-mz.122-37.SG1.bin.
When I attempt the command "switchport trunk encapsulation dot1q" it errors out.
Any idea why?
Thanks!
Edison Ortiz
What's the exact error?
Things to look out for:
Make sure the interface is set to Layer2 by entering the command
no switchport
Verify the module capabilities by entering the command:
show interface capabilities module x
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/53SG/command/reference/show1.html#wp2052389
If the Trunk Encap Type only list 802.1q and ISL is missing, there is no need to enter the command as any trunking configuration will default to 802.1q. All you need is to configure your trunk mode (ON, PAgP, LACP).
Edison
Edison Ortiz
no switchport
Edison
Thanks! You care corect.
Cheached capabilities and it can only handle 802.1q.
Port-channel2
  Model:                 N/A
  Type:                  N/A
  Speed:                 N/A
  Duplex:                half,full,auto
  Auto-MDIX:             no
  Trunk encap. type:     802.1Q
Port-channel2
  Model:                 N/A
  Type:                  N/A
  Speed:                 N/A
  Auto-MDIX:             no
Glad to be of help. Please mark this thread as resolved.
Edison
