TACACS+ local autenticacion
gerardor884
Hello I put the following command
aaa authentication login default group tacacs+ local
but for whatever reason when doing a test a loosing connection to the tacacs server the local user does not kick in as fallback
does anyone knows why?
do you have 'login authentication default' configured under your VTY lines ?
I have it like this
line vty 0 4
exec-timeout 30 0
privilege level 15
logging synchronous
but when you leave it blank, it is explicitly imply that the default method list is active isnt?
It should be implicit. You might as well retype it to be sure. Also, configure transport input all under the lines...
