techy8888
techy8888
I'm wondering if someone who did this before could guide me on where to start to uplift the whole environment in our Hospital.
I have asa firewall, two core switch, 2 distribution switches and 55 access switches.
My question is where do I start to change the network stuff ? Is it firewall first or core switches ?  Since Hospitals are 24/7 I want to make sure that I'm doing this the proper way so I don't get into a trap and downtime is way over what is expected for patient care
Thanks in advance for the tips you will give me
Jon Marshall
It's a bit hard to give any advice since you don't say what you want to achieve.
What are you trying to do ?
If the above is a full list of the equipment you have why do you have core switches ie. what is their purpose ?
Edit - the title of your post should really be a brief description of your question so others may find it of help if they have the same issue in future.
Jon
