755
Rising star
TengigE, Huge input drops
Hi Experts,
I have a question regarding a TengigE interface. i have this interface on a CRS-1 that has three Subif. all of the sub-interfaces are working without any problems, counters show no drops n basically all good. but when i run "show int" for the top-level interface, i can see a huge amount of "Input Drops".
is that normal or should i dig for a design flaw or an issue with the interface?
Thanks guys
Hope it Helps!
Soroush.
Everyone's tags (5)
1 REPLY 1
I'm not sure as I don't work on this platform very often.  Have a look at bug CSCti75606 and see if you think this might match your symptoms.
reference:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCti75606
Lp
Content for Community-Ad
July's Community Spotlight Awards
