07-23-2015 01:32 AM - edited 03-08-2019 01:04 AM
I have an aditional power supplly for a WS-C2960XR-48TS-I.
I woould like to know if I can insert this module in "HOT SWAP", I mean, I don´t want to swhudown the device.
07-23-2015 03:23 AM
Yes X series are hot swappable you can insert it without shutdown , then run command show env all to make sure it took ok
07-23-2015 11:57 AM
The Catalyst 2960-X switches comes with one fixed power-supply and options for an external redundant power supply source (RPS2300).
The Catalyst 2960-XR switches support dual redundant power supplies. The Catalyst 2960-XR ships with one power supply by default. The second power supply can be purchased at the time of ordering the switch or as a spare. These power supplies have in-built fans to provide cooling.
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/data_sheet_c78-728232.html
Since they support redundant PS, it is hot swappable as Mark said.
Madhu
