The CoS value is not trusted for 802.1P or 802.1Q tagged traffic.
mahesh18
Level 6
Level 6
Hi all,
i was reading this
Default Voice VLAN Configuration
The voice VLAN feature is disabled by default.
When the voice VLAN feature is enabled, all untagged traffic is sent according to the default CoS priority of the port.
The default CoS value is 0 for incoming traffic.
i need to understand that when we config the voice vlan on switch and assign the port to it.
now we attach the pc to phone.
1>The default CoS value is 0 for incoming traffic. -- this means traffic coming from pc to IP phone port   or
traffic coming from Phone to switch port?
2>The CoS value is not trusted for 802.1P or 802.1Q tagged traffic.   what does this mean  if someone can explain me this in detail ?
thanks
mahesh
2 Accepted Solutions
when you say that when we enable   mls qos globally that will  make  all interfaces untrusted by switch this means all interfaces connected  to
Cisco IP phone   only ??  or also the interface directly  connected to PC  ??
All the switch interfaces
if you can explain me please -------- the cos of tagged frames will not be overrided.??
yep of course: your cisco ip phone will mark traffic with voice traffic(RTP) with a cos of 5 so when it arrives on the switchport which trusts
the cos marking it will be retained by the switch and used to derive an internal DSCP value for use on non trunk ports where there is no tagging and so no cos.
But if the same traffic arrives on an untrusted port then the cos of 5 is reset to cos of switchport( by default 0) and then used to derive an internal
DSCP.
Regards.
Alain.
Yes that is right, if you configure MLS globally all ports are untrusted for best effort traffic. You can set a dscp value based on ACL or you can trust the COS /DSCP value on the switchport that comes from the PC or phone, but that is not so practical because every user can set its own COS value on the PC.
A simple method is, tag your desired traffic on the access switch, trust the dscp values on the uplinks to core/distri and set up a policy map.
Regards Martin
5 Replies 5
cadet alain
Traffic incoming on switch port, remember you are configuring QoS on the switch.
802.1P is the cos which is QoS marking for L2 ethernet 802.1q tagged frames.
Once QoS is enabled with mls qos global command then each interface is untrusted and has a cos value of 0 which means that tagged frames
coming in  with any cos value will get their cos reset to 0 by the switch.To trust the cos marking you have to enter the interface command
mls qos trust cos and so the cos of tagged frames will not be overrided.
Regards.
alain.
Hi alain,
many thanks  for reply
let see if i understand right
secondly  statement
thanks
mahesh
DSCP.
Regards.
Alain.
Regards Martin
Hi alain and Martin,
Many thanks for detailed explanation.
best regards
mahesh
