11-25-2010 12:18 PM - edited 03-06-2019 02:13 PM
Hi, I'm having trouble with a Cat SW 4500 with a supervisory II+ and a current IOS version 12.2(31)SGA. For unknown reason one of the blades stop sending power to most of their ports (1 to 25).
A year ago happens the same issue with the same blade.
The blade was physically reset without turn off the switch, after that the blade started to provide power on those ports. I notice that they are a new IOS version: 12.2(31)-SGA11(ED).
My concern is to known if the new version can fix PoE issues?
Thank you in advance,
Patricia.
11-25-2010 12:43 PM
Hello Patricia,
Honestly this looks like more an hardware issue or in the linecard itself or on the specific slot: power is taken from power supplies (if I remember correctly).
The only acceptable reason to stop sending power to some ports is a reduction of available power: in that case the switch choices to remove POE from some ports may be from a single linecard.
you can check this with
show environment
if there is available POE power this behaviour is not correct.
However, issues with a specific linecard model / IOS version cannot be excluded
relatively new.
Hope to help
Giuseppe
11-25-2010 03:10 PM
Hi Giuseppe, I'm attaching you the capture for 'show environment'.
switch#sh environment
no alarm
Chassis Temperature = 31 degrees Celsius
Chassis Over Temperature Threshold = 75 degrees Celsius
Chassis Critical Temperature Threshold = 95 degrees Celsius
Power Fan Inline
Supply Model No Type Status Sensor Status
PS1 PWR-C45-4200ACV AC 4200W good good good
PS1-1 220V good
PS1-2 220V good
PS2 PWR-C45-4200ACV AC 4200W good good good
PS2-1 220V good
PS2-2 220V good
Power supplies needed by system : 1
Power supplies currently available : 2
Chassis Type : WS-C4507R
Power consumed by backplane : 40 Watts
Switch Bandwidth Utilization : 0%
Supervisor Led Color : Green
Module 1 Status Led Color : Green
Module 2 Status Led Color : Green
Module 3 Status Led Color : Green PoE Led Color : Green
Module 4 Status Led Color : Green PoE Led Color : Green
Module 5 Status Led Color : Green PoE Led Color : Green
Fantray : Good
Power consumed by Fantray : 50 Watts
This does mean issues of hardware?
Patricia
