the stages of a packet throw a cisco switch
cniculescu
I'm tring to find a diagram of the succesion of functional blocks that a packet passes in his travel throw the switch/router.
input queue, the input acl, then input checks... monitor span, nat, filters, routing,cef.....
Thank you,
Ciprian
rwagner
hook up a packet sniffer and watch the traffic.  Wireshark is very common, but cisco also offers the EPC.
You can read more about the EPC here:
http://www.cisco.com/en/US/products/ps9913/products_ios_protocol_group_home.html
Giuseppe Larosa
Hello Ciprian,
a single diagram covering all the features you have mentioned does not exist probably.
you should look at different documents like
C6500 architecture
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_white_paper0900aecd80673385.html
C6500 QoS
be aware that QoS implementation in multilayer switches is different from that of routers and also there are big changes among different switch platform.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/qos.html
SW based router platforms implement the different stages in software.
Hope to help
Giuseppe
Ganesh Hariharan
Thank you,
Ciprian
Hi Ciprian,
Check out the below link on architucture of routers and switches for packet processing
http://www-europe.cisco.com/application/pdf/paws/5406/arch_1600_5406.pdf
Hope to Help !!
Ganesh.H
