04-09-2008 09:40 AM - edited 03-05-2019 10:17 PM
With the key word of "throttle" you seem to get everyone's interface statistics and never the information you're looking for.
So I'm asking here, why are we getting so many throttles on our VLANs?
Vlan1 is up, line protocol is up
Hardware is EtherSVI, address is 001b.8ffc.9c00 (bia 001b.8ffc.9c00)
Description: default
Internet address is 10.200.16.2/20
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 255/255, txload 7/255, rxload 4/255
Keepalive not supported
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 45w6d
Input queue: 0/75/79751948/26575486 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 16777000 bits/sec, 6522 packets/sec
5 minute output rate 28670000 bits/sec, 6836 packets/sec
L2 Switched: ucast: 52399326713 pkt, 18520446713681 bytes - mcast: 1682583532 pkt, 301081254038 bytes
L3 in Switched: ucast: 345017422861 pkt, 316321369118154 bytes - mcast: 0 pkt, 0 bytes mcast
L3 out Switched: ucast: 305044433420 pkt, 216792749551147 bytes mcast: 0 pkt, 0 bytes
348614577473 packets input, 317194848777630 bytes, 0 no buffer
Received 1111573878 broadcasts (817871 IP multicasts)
0 runts, 0 giants, 52195 throttles
311524636335 packets output, 218452799133117 bytes, 0 underruns
0 output errors, 0 interface resets
Vlan2 is up, line protocol is up
Description: 32Net
Internet address is 10.200.32.2/20
reliability 255/255, txload 2/255, rxload 2/255
Input queue: 0/75/50938683/8646073 (size/max/drops/flushes); Total output drops: 0
5 minute input rate 10413000 bits/sec, 3637 packets/sec
5 minute output rate 10977000 bits/sec, 3401 packets/sec
L2 Switched: ucast: 34953066787 pkt, 8296659020017 bytes - mcast: 863209733 pkt, 127440265628 bytes
L3 in Switched: ucast: 155634624605 pkt, 134265391332681 bytes - mcast: 0 pkt, 0 bytes mcast
L3 out Switched: ucast: 102022163187 pkt, 37398185658451 bytes mcast: 0 pkt, 0 bytes
156340289081 packets input, 134353633877832 bytes, 0 no buffer
Received 657482606 broadcasts (199486 IP multicasts)
0 runts, 0 giants, 49760 throttles
102162175761 packets output, 37416516902171 bytes, 0 underruns
04-09-2008 11:49 AM
You're also showing a very high number of input queue drops and flushes. What hardware platform are you running? Are any QoS policies defined?
04-09-2008 11:53 AM
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9-VM), Version 12.2(18)SXF8, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Sat 03-Mar-07 03:48 by tinhuang
Image text-base: 0x01020150, data-base: 0x01021000
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR:
MDF-Core uptime is 46 weeks, 3 days, 13 hours, 55 minutes
Time since MDF-Core switched to active is 46 weeks, 3 days, 13 hours, 55 minutes
System returned to ROM by power cycle (SP by power on)
System restarted at 01:54:38 EDT Sun May 20 2007
System image file is "sup-bootdisk:s72033-ipservicesk9-vz.122-18.SXF8.bin"
Cisco WS-C6509-E (R7000) processor (revision 1.3) with 1015808K/32768K bytes of memory.
Processor board ID SMG1113N5GV
SR71000 CPU at 600Mhz, Implementation 1284, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
42 Virtual Ethernet/IEEE 802.3 interfaces
148 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
We have "mls qos trust cos" set on about every port it looks like.
04-09-2008 12:27 PM
Sorry, when I do a show mls qos it says its disabled globally.
