Throughput 3560 vs 2951
alanc3141592654
Hey All,
I see the throughput of a ISR is 296.96 Mbps
how would this compare to a 3560 if the figure is 38.7Mpps?
What would the throughput of a 3560 be in Mbps?
Many Thanks
Arumugam Muthaiah
Please see the below throughput detail for 3560 series switches,
  • 32 Gbps forwarding bandwidth
  • Forwarding rate based on 64-byte packets:
  • 38.7 Mpps (Cisco Catalyst 3560G-48TS, Catalyst 3560G-48PS, Catalyst 3560G-24TS, and Catalyst 3560G-24PS);
  • 13.1 Mpps (Cisco Catalyst 3560-48TS and Catalyst 3560-48PS);
  • 6.5 Mpps (Cisco Catalyst 3560-24TS and Catalyst 3560-24PS);
  • 3.2 Mpps (Cisco Catalyst 3560-12PC)
  • 2.7 Mpps (Cisco Catalyst 3560-8PC)
In some other switches you can calculate it from the Linecards and Switch Fabric bandwidth as well. Fabric bandwidths are often quoted duplex, so for example, a 3560's 32 Gbps fabric would support up to 16 gig duplex ports w/o oversubscription; more port bandwidth may need more fabric bandwidth.
Wire-rate Ethernet, for 64 byte size packets requires 1.488 Mpps per gig, so 38.7 Mpps supports 26 Gbps (non-duplex) or about 13 gig duplex ports.  (NB: larger packets require a lower PPS, i.e. often same hardware's throughput increases with increased packet size.)
PS:
The later E and X series 3560s usually offer wire-rate perfomance for all ports.
Refer:
Cisco Catalyst 3560 Series Switches Data Sheet
http://www.cisco.com/en/US/partner/prod/collateral/switches/ps5718/ps5528/product_data_sheet09186a00801f3d7d.html
Aru
*** Please rate if the post is useful ***
Regards, Aru *** Please rate if the post useful ***
