Traceroute / HSRP / VRF
metzgersimon
when i make a traceroute on an ASR 1001 router to 172.23.30.7 I get the following output:
VRF info: (vrf in name/id, vrf out name/id)
  1 192.168.99.192 0 msec
    192.168.99.191 1 msec
  2 172.23.30.243 1 msec 1 msec 1 msec
  3 172.23.30.7 1 msec 1 msec 1 msec
Is there a loop between 192.168.99.191 and .192 (this are two routers with hsrp .190) or is this normal behaviour when using traceroute on an asr 1001?
Greetings,
Simon
Reza Sharifi
That is not a normal behavior.  Is HSRP configured correctly?
Can you post the HSRP configs from both routers?
Router1:
interface GigabitEthernet0/1
ip address 192.168.99.192 255.255.255.0
no ip redirects
no ip proxy-arp
standby 20 ip 192.168.99.190
standby 20 priority 140
standby 20 preempt
standby 20 authentication v21
Router2:
ip address 192.168.99.191 255.255.255.0
no ip redirects
no ip proxy-arp
standby 20 priority 120
standby 20 preempt
no ip route-cache
