Traffic Analyzer
Rawa Salah
HI all
please i want to run Netflow on my  CIsco switch 3750x-TE, but it seem doesn't support on it , could u please guide me to use another feature on cisco to work as netflow for traffic analysing ?
5 Replies 5
Ivan Shirshin
Hi Rawa,
You can use flexible netflow. Here is the link to the guide:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/software/release/15-0_1_se/configuration/guide/3750xcg/swmnetflow.html#wp1335576
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Dear Ivan
please i can't run the configuration of Flexible Netflow on my switch , please help
Hi Rawa,
Are you not able to configure it or encounter some issue during configuration?
Note that Flexible NetFlow is supported only on the Catalyst 3750-X and 3560-X switch running the IP base or IP services feature set and equipped with the network services module. It is not supported on switches running the NPE or the LAN base image.
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
Thanks Ivan
find my switch Model in below table
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3750X-24       12.2(55)SE5          C3750E-UNIVERSALK9-M
and running "IP services"
but I can't run first command of flexible netflow ( flow record ) this command is not available , so how can i configure !
please HELP
Dears
Please ANy update !!!
