Traffic between VLAN.
mahmoodkhd
Dears ,
I have question regarding to control traffic between VLAN.  My VLAN located in Core switch and I need to prevent VLAN 10 from Accessing VLAN 20 and the same time I need VLAN 20 to access VLAN 10.
  Please Advice
Sandeep Choudhary
Hi Mahmood,
how to block access from  vlan 1 to other vlan 2:
access-list 100 deny ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 100 permit ip any any
applied
interface vlan1
ip access-group 100 in
Please rate if it helps.
if you do this then you will also restrain vlan  2 to speak to vlan 1, don't forget that IP communication is bidirectionnal.
Regards.
Alain
Hi Alain,
You are right, it will block from both side.
REgards
