Traffic does not go through hsrp ip address
wfqk
Contributor
Contributor
Hi Two Nexus7K have configured with hsrp with its address 10.1.1.1 and 10.1.1.2 respectively. The vlan address for this hsrp is 101.1.3 After traceroute, i noticed the traffic goes through 10.1.1.1 instead of 10.1.1.3
Do you think this would have any issue? Thank you
Rob Ingram
VIP Expert VIP Expert
VIP Expert
Hi, That shouldn't be a problem, 10.1.1.1 is defined as the active HSRP address. When you do a traceroute each hop will send a TTL exceeded in transit message back from the real IP address of the router or switch. In this instance you know traffic is routed via 10.1.1.1
Rob Ingram
VIP Expert
Joseph W. Doherty
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
What you might want to check is see what MAC the host has in its ARP table for 10.1.1.3 and 10.1.1.1. If it's the virtual MAC of 10.1.1.3, and Rji notes, it shouldn't be a problem.
Recognize Your Peers
