translation problem!
wvangemd
Can any one help with this?/ I am getting this error!
No translation group found for tcp src interconnect x.x.x.x/56095  dst test x.x.x.x/443
cadet alain
are you trying to connect from outside to a machine on port 443 ? Then you have no static NAT configured for this translation.
Can you post sh ip nat trans and sh run | s nat
Regards.
Alain
In addition can you please share your NAT Configuration as well?
-Vijay
wvangemd
Hello Guys,
Thanks for your reply. I've found the problem there was a nat rule missing.
