Trap to monitor FEX on 5K
vivek_tech2003
Could anyone please let me know which trap we need to enable to monitor FEX module on 5K.
If FEX goes down due to link failure/power down we do not receceive any trap on SNMP server.
Your help is highly appreciated.
Ethernet1/5 is where Fex module in connected on 5K
Some sample log
2013 Jan  4 12:11:32switch1 %FEX-5-FEX_PORT_STATUS_NOTI: Uplink-ID 1 of Fex 103 that is connected with Ethernet1/5 changed
its status from Connecting to Active
2013 Jan  4 12:11:32switch1 %ETH_PORT_CHANNEL-5-PORT_UP: port-channel103: Ethernet1/5 is up
2013 Jan  4 12:11:32switch1 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel103: first operational port changed from none to E
thernet1/5
2013 Jan  4 12:11:32switch1 %ETHPORT-5-IF_UP: Interface Ethernet1/5 is up in mode Fex Fabric
2013 Jan  4 12:17:04switch1 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel103: first operational port changed from Ethernet1
/5 to none
2013 Jan  4 12:17:04switch1 %FEX-5-FEX_PORT_STATUS_NOTI: Uplink-ID 1 of Fex 103 that is connected with Ethernet1/5 changed
its status from Active to Disconnected
2013 Jan  4 12:17:04switch1 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel103: Ethernet1/5 is down
2013 Jan  4 12:17:05switch1 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/5 is down (Link failure)
2013 Jan  4 12:17:06switch1 %FEX-5-FEX_PORT_STATUS_NOTI: Uplink-ID 1 of Fex 103 that is connected with Ethernet1/5 changed
its status from Disconnected to Configured
2013 Jan  4 12:17:06switch1 %ETHPORT-5-SPEED: Interface Ethernet1/5, operational speed changed to 10 Gbps
2013 Jan  4 12:17:06switch1 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/5, operational duplex mode changed to Full
2013 Jan  4 12:17:06switch1 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/5, operational Receive Flow Control state ch
anged to off
2013 Jan  4 12:17:06switch1 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/5, operational Transmit Flow Control state c
hanged to off
2013 Jan  4 12:17:06switch1 %FEX-5-FEX_PORT_STATUS_NOTI: Uplink-ID 0 of Fex 103 that is connected with Ethernet1/5 changed
its status from Configured to Fabric Up
2013 Jan  4 12:17:07switch1 %FEX-5-FEX_PORT_STATUS_NOTI: Uplink-ID 1 of Fex 103 that is connected with Ethernet1/5 changed
its status from Fabric Up to Connecting
2013 Jan  4 12:17:07switch1 %ETH_PORT_CHANNEL-5-PORT_UP: port-channel103: Ethernet1/5 is up
2013 Jan  4 12:17:07switch1 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel103: first operational port changed from none to E
thernet1/5
2013 Jan  4 12:17:07switch1 %ETHPORT-5-IF_UP: Interface Ethernet1/5 is up in mode Fex Fabric
2013 Jan  4 15:12:16switch1 %FEX-5-FEX_PORT_STATUS_NOTI: Uplink-ID 1 of Fex 103 that is connected with Ethernet1/5 changed
Thanks in advance.
ThinMan
I need some advice on this as well. we are currently in the process of configuring our 5k's and 2k Fex. not sure wehther the 2ks  will show up as an interface (In SNMP monitoring) when connected ? or do we need to do a special configuration, mib etc ?
Could someone help please ?
Hello, did you receive any answer to your question or do you have a solution for this issue? I have the same problem but no idea!
Did you configure the following for snmp?
(config)# snmp-server enable traps entity ?
  <CR>
  entity_fan_status_change     Entity Fan Status Change
  entity_mib_change            Entity MIB change
  entity_module_inserted       Entity Module Inserted
  entity_module_removed        Entity Module Removed
  entity_module_status_change  Entity Module Status Change
  entity_power_out_change      Entity Power Out Change
  entity_power_status_change   Entity Power Status Change
  entity_sensor                Entity sensor
  entity_unrecognised_module   Entity Unrecognised Module
Kind rgds
eganclose
Did u manage to get answer for this ?
