Trouble Removing 3750 from stack
grahamhyland
Hi all,
I have a 3750 on my desk which I’m using for new site, I removed this from a previous stack of 4 configuration.
I ran the no switch 4 provision ws-c3750g-24ts on the stack after I powered it down and removed it. (no problems it was switch 4)
I then erased the startup config and reloaded , I went through the basic setup wizard etc and set it up, however the intefaces are still named like they were in the stack.
Ie
interface GigabitEthernet4/0/1
interface GigabitEthernet4/0/2
interface GigabitEthernet4/0/3
also switch 4 provision ws-c3750g-24ts is in the config on this switch (is this strange?)
I tried the no switch 4 provision ws-c3750g-24ts on this but the result is
SW1(config)#no switch 4 provision ws-c3750g-24ts
%Switch can not be un-provisioned when it is physically present
Its not a real problem as the switch will still work but I would like to keep it tidy?
glen.grant
  Try "switch 4 renumber 1 ,  save and reload .
I ran switch 2 renumber 1
wr
reload
Now I see all interfaces as 1/0/.. and also 2/0/..
How can I remove the interfaces from switch 2?
use "no switch stack-member-number provision" command
Evert0505
Hi I head the same problem, you can use te following to fix this:
#switch 4 renumber 1
#do rw
and "reload"
If you see also 1/0/1 and 2/01 you can use the bellow command to remove 2
#no switch 2 provision
