Trouble with vlan/trunking on 1142+2960S+ASA5505
Samuel Eng
Beginner
Beginner
Hi, I'm trying to configure an 1142N AP +  2960-S + ASA5505 with wireless, vlans and trunking with no success. DHCP is provided from my DHCP-server on the inside. Here's my config:
Thanks/Sam
AP
version 12.4
no service pad
service password-encryption
hostname AP-TRI-LABB
enable secret 5 $1$6Xtu$1v76qIsBXYBEFPJO6tiyX/
no aaa new-model
ip domain name triathlon.local
dot11 syslog
dot11 ssid TRI-LABB
   vlan 80
   authentication open
   authentication key-management wpa version 2
   mbssid guest-mode
   wpa-psk ascii 7 03104902071B29404107
username Cisco password 7 062506324F41
username admin privilege 15 secret 5 $1$EWxG$.l0ECJtBxrnbZldnVbbwQ0
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 80 mode ciphers aes-ccm
ssid TRI-LABB
antenna gain 0
mbssid
channel 2467
station-role root
interface Dot11Radio0.80
encapsulation dot1Q 80 native
ip helper-address 192.168.1.20
no ip route-cache
bridge-group 80
bridge-group 80 subscriber-loop-control
bridge-group 80 block-unknown-source
no bridge-group 80 source-learning
no bridge-group 80 unicast-flooding
bridge-group 80 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid TRI-LABB
antenna gain 0
no dfs band block
mbssid
channel width 40-above
channel dfs
station-role root
interface Dot11Radio1.80
no ip route-cache
bridge-group 80
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.80
no ip route-cache
bridge-group 80
interface BVI1
ip address 192.168.1.32 255.255.255.0
no ip route-cache
ip default-gateway 192.168.1.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
2960-S Switch   (port 1 to AP, port 24 to ASA)
version 12.2
no service pad
hostname TRIGOTSW01
boot-start-marker
boot-end-marker
enable password TgbYhn!23
no aaa new-model
switch 1 provision ws-c2960s-24ps-l
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
ip address 192.168.1.41 255.255.255.0
interface GigabitEthernet1/0/1
switchport trunk native vlan 80
switchport mode trunk
switchport nonegotiate
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
no ip address
shutdown
ip http server
ip sla enable reaction-alerts
line con 0
line vty 5 15
end
ASA5505 (port 0/3 to switch)
hostname TRIGOTASA01
domain-name triathlon.local
enable password v4fmcWqoQy.l8i1X encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
shutdown
no nameif
security-level 100
no ip address
interface Vlan2
nameif outside
security-level 0
ip address x.x.x.x 255.255.255.248
interface Vlan10
nameif inside
security-level 100
interface Vlan80
nameif wireless
security-level 100
ip address 192.168.80.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
switchport access vlan 10
interface Ethernet0/2
interface Ethernet0/3
switchport trunk allowed vlan 2,10,80
interface Ethernet0/4
interface Ethernet0/5
switchport trunk native vlan 10
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network OBJ-INSIDE
subnet 192.168.1.0 255.255.255.0
object network OBJ-VPN
subnet 192.168.50.0 255.255.255.0
object network OBJ-WIRELESS
subnet 192.168.80.0 255.255.255.0
access-list SSLVPN_SPLIT_TUNNEL standard permit 192.168.1.0 255.255.255.0
pager lines 24
logging enable
logging buffered informational
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu wireless 1500
mtu labb 1500
ip local pool VPN_POOL 192.168.50.100-192.168.50.130 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit any wireless
asdm image disk0:/asdm-641.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) source static OBJ-INSIDE OBJ-INSIDE destination static OBJ-VPN OBJ-VPN
nat (inside,outside) dynamic interface
nat (wireless,outside) dynamic interface
route outside 0.0.0.0 0.0.0.0 83.218.72.241 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
aaa authentication telnet console LOCAL
aaa authentication http console LOCAL
aaa authentication serial console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
http 192.168.1.0 255.255.255.0 wireless
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 20 set ikev1 transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto ikev1 enable outside
crypto ikev1 policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 5
ssh version 2
console timeout 0
management-access inside
dhcpd auto_config outside
dhcprelay server 192.168.1.20 inside
dhcprelay enable wireless
dhcprelay timeout 60
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 192.36.133.17 source outside prefer
webvpn
enable outside
anyconnect image disk0:/anyconnect-macosx-i386-2.5.3055-k9.pkg 1
anyconnect image disk0:/anyconnect-linux-2.5.2014-k9.pkg 2
anyconnect image disk0:/anyconnect-win-2.5.3055-k9.pkg 3
anyconnect enable
tunnel-group-list enable
group-policy SSLVPN internal
group-policy SSLVPN attributes
dns-server value 192.168.1.10
vpn-tunnel-protocol ssl-client
split-tunnel-policy tunnelspecified
split-tunnel-network-list value SSLVPN_SPLIT_TUNNEL
default-domain value triathlon.local
split-dns value triathlon.local
address-pools value VPN_POOL
group-policy TRIGROUP internal
group-policy TRIGROUP attributes
username admin password EzAev6eqAFlJ7Hg7 encrypted privilege 15
tunnel-group WEBVPN type remote-access
tunnel-group WEBVPN general-attributes
default-group-policy SSLVPN
tunnel-group WEBVPN webvpn-attributes
group-alias WEBVPN enable
tunnel-group vpngroup1 type remote-access
tunnel-group vpngroup1 general-attributes
address-pool VPN_POOL
default-group-policy TRIGROUP
tunnel-group vpngroup1 ipsec-attributes
ikev1 pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
  inspect ip-options
  inspect pptp
Giuseppe Larosa
Hello Samuel,
on access point you should use BVI80 instead of BVI1, bvi number should follow the bridge group number it tells to which bridge group it refers to.
On ASA you have configured under vlan80 ip address 192.168.80.x  but on AP you have 192.168.1.y on BVI they are in different IP subnets so you need to fix taking a decision.
Hope to help
Giuseppe
Ok, but naming it BVI80 is necessary?
And I thought natives vlans was created for giving the AP an adress that is in the management subnet (vlan 10?) I've done this before without the switch inbetween.
Hello Samuel,
yes unless you change all the commands referring to bridge-group 80 in bridge-group 1
in current configuration native vlan is 80 everywhere if you want to change it to 10 you can of course.
Hope to help
Giuseppe
Ok, my bad. I've changed all the native vlans on the routerport and switchports but it's still not working. I'm suspecting something with the AP-configuration? Not getting any DHCP-adress and no connectivity when I use a static address...
