trunk between switches
sarahr202
Level 5
Level 5
hi every body!
i just want to confirm the following:
sw1(config-if)#switchport
#switchport mode dynamic desirable
sw2(config-if)#switchport
# switchport mode dynamic desirable.
Will the trunk form? or do we need to use the command: switchport trunk encapsulation negotiate on both switches?
thanks a lot!
3 Accepted Solutions
lejoe.thomas
Level 3
Level 3
Sarah,
yes the trunk will form between the two switches.
Lejoe
Edison Ortiz
switchport trunk encapsulation negotiate is the default setting on a switchport, thus there isn't a need to enter such command.
A switchport will form a trunk under the following modes.
Desirable<->Desirable
Desirable<->Auto
on<->on
Please refer to table 12.4 from this URL
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_44_se/configuration/guide/swvlan.html#wp1096213
HTH,
__
Edison.
ropethic
Level 4
Level 4
Switch A - Switch b
auto - on or desirable
desirable - on, desirable, auto
nonegotiate - on
lejoe.thomas
Level 3
Level 3
Sarah,
Lejoe
Edison Ortiz
Desirable<->Auto
on<->on
HTH,
__
Edison.
ropethic
Level 4
Level 4
Switch A - Switch b
nonegotiate - on
