trunk link settings
lcaruso
Level 6
Level 6
Can someone tell me why you would want to use these settings on a trunk to another switch from a core switch?
I have found some other issues in this evironment regarding switch configurations and I need to determine why this might be done and if it represents a correct configuration for the given environment.
Thanks.
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue input bandwidth 70 30
mls qos srr-queue input threshold 1 80 90
mls qos srr-queue input priority-queue 2 bandwidth 30
mls qos srr-queue input cos-map queue 1 threshold 2 3
mls qos srr-queue input cos-map queue 1 threshold 3 6 7
mls qos srr-queue input cos-map queue 2 threshold 1 4
mls qos srr-queue input dscp-map queue 1 threshold 2 24
mls qos srr-queue input dscp-map queue 1 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue input dscp-map queue 1 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue input dscp-map queue 2 threshold 3 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue output dscp-map queue 1 threshold 3 46 47
mls qos srr-queue output dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 2 threshold 1 26 27 28 29 30 31 34 35
mls qos srr-queue output dscp-map queue 2 threshold 1 36 37 38 39
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 4 threshold 1 8 9 11 13 15
mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
mls qos queue-set output 1 threshold 1 100 100 50 200
mls qos queue-set output 1 threshold 2 125 125 100 400
mls qos queue-set output 1 threshold 3 100 100 100 400
mls qos queue-set output 1 threshold 4 60 150 50 200
mls qos queue-set output 1 buffers 15 25 40 20
mls qos
interface GigabitEthernet2/1/1
switchport mode trunk
srr-queue bandwidth share 1 30 35 5
queue-set 2
priority-queue out
mls qos trust dscp
auto qos trust dscp
lcaruso
Level 6
Level 6
Actually I just noticed they have the exact same setting (no trunk) going to some access ports as well.
interface GigabitEthernet3/0/46
switchport access vlan 50
switchport mode access
switchport nonegotiate
switchport voice vlan 2
queue-set 2
priority-queue out
mls qos trust cos
auto qos trust cos
spanning-tree portfast
Hello Sir.
That's someone lazy : ), doing a interface range command from global configuration mode and pasting the configuration just once for all interfaces.
Regards.
Wilson B.
HBernard
Not only lazy, but lazily wrong.  The config on the interface shows:
queue-set 2
priority-queue out
mls qos trust dscp
auto qos trust dscp
Unless the full configuration wasn't posted, there is no queue-set 2 defined.
Regards.
HB
Hello
The configuration is part of mls qos and it looks like its auto mls qos macro features.
srr priority queuing is enabled with define input traffic for these interfaces set to queue 2 .
Also output queuing bw sharing is set for the 4 queues
Res
Paul
Kind Regards
Paul
