Trunk Ports between switches
mrmarie
Beginner
Beginner
Hello
What the the recommended command should I apply for Trunk ports between edge switches in the below digram to avoid looping in the network.
Appreciate your help
Tyson Joachims
Rising star
Rising star
Apply the same trunk configuration as all the other switches. Spanning tree protocol (STP) will take care of preventing loops automatically. It is best practice to run the same kind of STP throughout the whole network as to prevent odd issues.
Hello Georg,
Sorry, I mean Trunk ports between switches, so there is any configuration should I do in edge switches for spanning-tree.
Georg Pauwen
VIP Master VIP Master
VIP Master
what do you mean by 'true' ports ? All ports should be trunk ports, make the core switch the root for all Vlans, and spanning tree will block one of the outgoing ports, hence avoiding a loop.
MHM Cisco World
VIP Mentor VIP Mentor
VIP Mentor
Core is Root always
link between SW2-SW3 always block
this give you best STP config
Recognize Your Peers
