09-17-2010 03:29 AM - edited 03-06-2019 01:02 PM
hi all
i have an access, dist and core design with layer 3 ports between my dist and core.
what QOS setting do i need to apply on these layer 3 ports, is the mls qos dscp trust enough, or would I need to apply a policy map to the layer 3 ports ?
cheers
Carl
09-17-2010 03:57 AM
Hi Carl,
Assuming packets are marked properly on access layer, trust DSCP is enough, no need to apply policy-map on distribution layer to remark packets. If the platform is cos based queueing, then you might need to modify the DSCP-COS map; otherwise, the default map will be used to get COS from DSCP.
HTH,
Lei Tian
09-17-2010 04:20 AM
so are you saying I can use this between my distribution and core layer 3 ports with ip addresses on them ?
09-17-2010 05:30 AM
Yes.
09-17-2010 06:25 AM
Carl,
As lei mentioned, the traffic has been correctly marked previously by the access switches, therefore you do not need to make any remarking, but you need to ensure that you do trust the incoming DSCP by applying "mls trust dscp" on your distribution and core siwtch. This is the easiest case, as all ports will be marked as trust-dscp and that should be sufficient:
Francisco.
