Unable to Connect lawn sprinkler to Home Gateway 5.1.1.2 Smart Home
kevinmalingu
No fastethernet0 on sprinkler to connect a copper straight through cable. I keep getting the same error message.
pieterh
most possibly you need wireles connection like Wi-Fi /  BlueTooth / Zigbee, to connect to the gateway
not fast-ethernet , which is wired !
marishap
You need to add an ethernet interface to the sprinkler. Click on the Sprinkler and the settings box will open. Click on "Advanced" button at the bottom and follow these steps. Hopefully it helps.
